Scooba 230 Dis-assembly
alexmad
Re: Scooba 230 Dis-assembly
Post by alexmad »
Hi Serge_ISA!
I need some help! Could you please tell me what does the resistor in blue on the picture reads?? I know that it ends by XXXR9. I broke it, and it could be the reason why my motherboard is no longer active (I dont think so, but dreaming is free).. Thanks!
Alejandro
Serge_ISA
Post by Serge_ISA »
alexmad wrote:Could you please tell me what does the resistor in blue on the picture reads?? I know that it ends by XXXR9. I broke it, and it could be the reason why my motherboard is no longer active
Hi!
This resistor marked as 90R9 - 90,9 Om.
PS: I updated my photo with connectors pinout.
PPS: My Scooba has learned to ride with new selfmade controller. :lol:
Serge_ISA
Post by Serge_ISA »
Hi!
I again updated image with connector pinout on page 3.
Only two connectors remained unknown - 3-pin nearby Pumping_motor_connector and 2-pin nearby Speaker_connector.
Speaker connector marked on PCB as "CTF / Speaker".
Does anyone know what the sensor is called "CTF"?
Compound is deleted for new PCB
alexmad
Post by alexmad »
Omg! You did a great job!, hours and hours invested! I parked my roomba to build a 3d printer so can be of no help sorry!
Congrats yous should post some stuff about your new controller ;)
third_deg
Post by third_deg »
CTF? Sure it's not CTE? That would be Clean Tank Empty sensor
Serge_ISA
Post by Serge_ISA »
third_deg wrote:CTF? Sure it's not CTE? That would be Clean Tank Empty sensor
Right! "CTE"! Thanks!
Only one connectors remained unknown - 3-pin nearby Pumping_motor_connector.
IMHO this is "Robot lifted" (I do not know how to say) or IR-sensor for Virtual_Wall detected.
third_deg
Post by third_deg »
--There are no wheel drop sensors on the 230. It uses the cliff detectors for that.
The IR sensor used for the Virtual walls, does have three wires though if I remember right. Part of the goal was to delete as many sensors as possible for this product.
So you have:
(2X) bumper switches
(3X) Cliff
(1X) RCON sensor
(1X) CTE sensor
No wheel encoders, no wheel drop switches, no dirty tank full sensor....
So if you have identified all of the power outputs such as wheels, charging, pump, fan, speaker etc, and only worried about sensors, then the one remaining sensor is the VW/RCON sensor.
Serge_ISA
Post by Serge_ISA »
third_deg wrote:So if you have identified all of the power outputs such as wheels, charging, pump, fan, speaker etc, and only worried about sensors, then the one remaining sensor is the VW/RCON sensor.
You're right - it's probably the VW/RCON sensors connector. Maybe you know pinout/shematics of this sensor?
(One of 3 pin of this connector connected to + of big capacity).
third_deg wrote: ... no wheel drop switches...
This is most likely correct, but one thing bothers me. On the left wheel has a steel rod (look at the photos).
It passes into the tank. Maybe it opens and closes the clear_water_valve?
Contact:
Post by piokrza »
Serge_ISA wrote:On the left wheel has a steel rod (look at the photos).
It opens/closes the vacuum impeller compartment.
third_deg
Post by third_deg »
As Piozkrza says...
This Rod simultaneously opens / closes 3 ports. One over each tube leading up from the squeegee compartment, and a third over the fan.
That way as soon as you lift the robot, the dirty tank inputs are closed.
third_deg
Post by third_deg »
Also...
No water valve needed. The peristaltic pump only flows when energized, so it doesn't need any valves.
Contact:
Post by piokrza »
that's the answer why it stay in pool of water after cycle complete
Serge_ISA
Post by Serge_ISA »
Last update for connectors pinout on page 3 - http://www.robotreviews.com/chat/viewto ... 88#p124488
third_deg wrote: So you have:
(3X) Cliff
(1X) RCON sensor
(1X) CTE sensor
Summary for sensors:
2 x Bumper switches
3 x Cliff IR-sensors
1 x Wall IR-sensor
1 x Clear_Tank_Empty sensor
1 x Virtual_Wall/RCON IR-sensor
1 x Battery temperature sensor
And additional sensors:
1 x Pumping_Rotate_Speed (hercon on PCB + magnet on pump rotor)
1 x unknow strange optic sensor on PCB
alexmad wrote:yous should post some stuff about your new controller ;)
I plan to finish in a week. Apparently it is better to open a new topic?
third_deg
Post by third_deg »
True true....
Forgot about those others! Good work
Contact:
Post by piokrza »
I thought there was no VW sensor, but cliff sensors had 'mirrors' or other 'lenses' directed to upper part of the bumper...at least, when I (finally) disassembled the bumper from 230's body, I did not noticed any sensor in its upper area (where VWs window is located).
Also, Scooba 230 has probably some type of clean water sensor (because of 'Error no. 1' - clean water tank is empty)
http://homesupport.irobot.com/app/answe ... /a_id/1116
third_deg
Post by third_deg »
VW sensor is built into the top of the robot, and the edge of the top light pipes the signal to it.
And yes, CTE sensor.
joepesce
Post by joepesce »
hi all, I have scooba 230 with broken tank... do you think it's possible to fix?
Post by vic7767 »
IMHO, save yourself some aggravation and pick uo a 300 model Scooba. At least when it breaks you have some maintenance options available that will allow you to disassemble it and make repairs.
joepesce
Post by joepesce »
vic7767 wrote:IMHO, save yourself some aggravation and pick uo a 300 model Scooba. At least when it breaks you have some maintenance options available that will allow you to disassemble it and make repairs.
I have scooba 380 and another scooba 230 :P
I'm looking for some way to disassemble and make minor damage possible
my scooba 230 is perfectly functional except for the tank... is really sad to throw it away
Post by vic7767 »
joepesce wrote:is really sad to throw it away
Welcome to the 230 club. It has been suggested that possibly the use of some liquid epoxy or rubber sealer might be able to seal a broken 230 bladder.
