Neato XV21 - What repairs do I need?
Boomerang
Post by Boomerang »
I have the XV21 since 10-2012. It would clean a whole room on one charge.
Problems I'm having lately:
1) It needs to stop and charge while cleaning this room which didn't happen in the past.
2) Hardly anything is in the Dirt Bin. What is in there is right up against the filter.
Do I need a new battery or a new filter or is it a bigger problem because it doesn't seem to be picking up much?
Maybe someone here had these problems and can advise me?
Thank you. :shock:
Contact:
Re: Neato XV21 - What repairs do I need?
Post by glnc222 »
Battery life is 200-300 charging cycles. When capacity falls, it has shorter run time.
Boomerang
Post by Boomerang »
Does the shorter run time affect the suction power. Hardly any dirt in the Bin and what little is there is right up against the filter.
Boomerang
Post by Boomerang »
Boomerang
Post by Boomerang »
Boomerang
Post by Boomerang »
Boomerang
Post by Boomerang »
Why did 3 extra messages save?
Post by vic7767 »
You can delete them by clicking on the (x) on the upper right of your post. This just happens sometimes.
While replacing your battery pair, also replace your filter. Once all the new goodies are installed then see how the run times and dirt bin contents improve by sending it on a new cleaning session.
Boomerang
Post by Boomerang »
vic7767 wrote:You can delete them by clicking on the (x) on the upper right of your post. This just happens sometimes.
I was looking for a way to delete the message - there is no X in the upper right of my post. (It just appeared with this message - thanks)
I'll order the battery and see what happens. Hope it's easy to install. :roll:
Contact:
Post by glnc222 »
Deleting posts only works when the last post in thread -- in case someone referenced the post later. They can be edited to blank or "duplicate deleted" etc.
Only diagnostic tests over USB and experiments can identify what, if anything, is wrong with the Neato. A very short run time, in a relatively clean space, is not going to pick up much dirt.
Not much can be said without very detailed observations and the complete history of the machine etc.
[edit] a clogged filter can also prevent dirt pickup. Or a brush turned off. A known-good battery is needed. It's a complex system.
Boomerang
Post by Boomerang »
New Batteries are selling at $49.+ for 2 on Amazon. Seems expensive for a test. My 6 year old iRobot Roomba 580 didn't have battery problems in 2 years. Is there a program that's needed to do the diagnostic tests?
Post by vic7767 »
Two things are needed in order to query the Neato for sensor information. Your USB cable used to flash the Neato along with the software download driver and of course a PC terminal program to allow you to send and receive info between the Neato and the PC.
Boomerang
Post by Boomerang »
"Software download driver" ? Do I get this at Neato Support with instructions?
Contact:
Post by glnc222 »
You would normally register the unit under MyNeato at Neato's website, and see links to software updates.
Without completing an update, the first step to download the driver or "update tool" will be shown.
See the mods list top of main page for NeatoControl program, and the USB command manual for using telnet programs such as Putty or Hyperterminal.
There are many issues to examine before analyzing specific components over USB. Whether the filter is good, the age of the battery, frequency of use, whether the brush and fan are working, navigational performance etc. There is more to see than just "doesn't clean well". Clean what? How much dirt? How often? How long in use? What problems has it had in the past? What brush? Have the blades been replaced for wear? How worn are they?
If it cleans one room, which room? Any difference between single room runs in different rooms?
The USB commands will not tell you much whether the filter is good except by examining the vacuum current load running, which will be very low when clogged compared to something near 1 amp or more for a new filter.
Contact:
Post by glnc222 »
Neato and Roomba battery use cannot be perfectly compared. Neato makes heavy use of a battery which requires replacement every 1-1.5 years according to the manual (200-300 charging cycles as mentioned). This is consistent with the specifications for these types of batteries, determined by the particular cell technology used.
So to the brass tacks: how much has the battery in this Neato been run? How many times per day, how many days per year, how many years? They require almost annual replacements.
Post by mfortuna »
My first set of batteries lasted maybe 50 charge cycles. I only use the Neato once a week.
Post by vic7767 »
Early Neatos were like the early 5900 Scoobas. The charging system was basically cooking the packs. Heat is not a friend to NiMH cells. I had several XV-11 rev 113 boards on 2.1 that caused early pack failures.
Boomerang
Post by Boomerang »
mfortuna wrote:My first set of batteries lasted maybe 50 charge cycles. I only use the Neato once a week.
I do not use it much either. Maybe it would be better to take it off the base and recharge the night before use? Don't know whether this would add extra cycles to the batteries. :?
Boomerang
Post by Boomerang »
glnc222 wrote:You would normally register the unit under MyNeato at Neato's website, and see links to software updates.
I guess they've changed the web site because the mods list is not there.
Contact:
Post by glnc222 »
