Anyone attach Swiffer pads on Braava Jet?
News and information about the iRobot Braava - formerly the Evolution Mint Robotic Cleaner. All discussion and troubleshooting questions go here.
slam_to
Post by slam_to »
Just wondering if anyone had managed to find a way to attach the Swiffer "wet mopping" (pre-moistened pads) to a Braava Jet? I'm not referring to the 300 series Braava!
I was thinking of trying to attach it (either pinning it, or some other method) to the Jet's washable pads. I have quite a few boxes of the Swiffer pads, and want to use them up.
Anyone try it, or have another method?
S.Lam
kondi
Re: Anyone attach Swiffer pads on Braava Jet?
Post by kondi »
Have you managed to attach is somehow?
aznoohwee
Post by aznoohwee »
I've done this. If you have a 3d printer handle, print these two files. You will need to look at the original sweeper pads and copy the line template for the sensor. Tape the lines over the square holes for the sensor oriented in the same direction as the original pad. Use velcro to attach the base plate to the adapter. Place strips of velcro on the other side to allow the swiffer pad to stick to the adapter. Wrap the swiffer around the sides adapter.
https://www.thingiverse.com/thing:2468701
Cheers!
