https://kobold.vorwerk.de/service/servi ... ease-notes
Unzip it... unzip the tar tgz....
Neato_4.5.1_186.bin ... with cert files.
Anyone been poking around at all on these?
That seems correct.masterx81 wrote:Uhm, 4.5.1 wasn't an update available for d series. Latest is 4.5.3-189
Being it uses what looks to be a slightly custom ARM CPU based around the TI 962/962B ARM CPU.. linux variant.Scapegoat wrote:I managed to get access to the "Neato_4.5.3_189.tgz" Firmware. It contains the same files that you're seeing:
"Neato_4.5.3_189.bin"
"Neato_4.5.3_189.signed"
"Signing.crt"
So far no luck with the ".bin" but in a hex editor I do see the model numbers like you mentioned.
Does anyone know what type of OS the Neato is running? Some sort of Embedded Linux? It would help to know what type of SOC (chipset) the Neato has.
Edit:
Just noticed that Neato released some sort of XV toolchain here: https://www.neatorobotics.com/lab/linux/
Interesting, anyone know why they made this available?
Interesting doc @ https://www.usenix.org/system/files/woo ... llrich.pdf
Sure, I just sent it to you in a PM for now since the forums won't let me upload it. I saw on one of your posts that you have a few Neatos that you seem to hack around with. Would be great if you could try some of the stuff from the white paper.jdredd wrote:Any way I can get a copy of the Neato_4.4.0_72.tgz ?
Still need to do more research to determine that. Since the ".bin" seems to have a Neato header at the top (version info, model info, etc) it's possible that Neato compresses or encrypts the image somehow.jdredd wrote:Need to find a tool that can handle the QNX Neutrino flavor I take it.. ?
