Mavrik wrote:Gordon wrote:solid lubricants will quickly be pushed out of the load-zone
This can be said for liquid lubricants as well, unless there is a sealed reservoir and gears submersed.
You are not visualizing the macro-picture. The "reservoir" here, is the small gap that exists in the non-load region between hub and static material. Its volume is on the order of a liquid 'droplet'. Liquid lubricant is retained in that gap by capillary force. Question: What force is there, that retains particles of dry-lube which may be pushed aside, longitudinally out of the bearing?
Note that my rejection of dry lubricants originally applied to member "fugli's" question about using a Teflon-based dry lubricant. I presume you read his May 17th post, and subsequent posts, above.
While graphite has slightly conductive properties, just like dirt and dust, it seems to adhere to allot of surfaces. ...
I fail to see what conductivity has to do with retention of graphite, I'm quite certain the graphite platelets find homes in the pits, fissures, cavities, scratches (roughness) which most any commercially finished surface exhibits. As the plastic hub wears, those islands of reserve graphite will come into play and help reduce friction.
... I applied some graphite to a piece of glossy white nylon and I couldn't rub it off with my fingers, it just smeared.
That is not a very satisfying 'test'. You need to rapidly move the two surfaces past each other at the rate the Roomba gear-hub travels, and emulate a load-force equivalent to the floor pushing up on the brush while it revolves for 30 to 90 minutes.
A nylon to nylon application would just embed the graphite into the gears. This would result in permanently dry lubed gears. ...
Give it a try, for about 100 hours of run-time, and tell us about it.
I agree that graphite and moly-disulphide dry lubes have the best chance of working. However, I think many owners would not care for the black-mess experienced by applying either of those materials. Also, it seems to me there would be a bit of hassle injecting the powder into the thin annulus around gear-hubs; even with the usually provided applicator that is intended to service tumbler-type key locks.
I prefer to apply a drop or two of viscous oil just prior to each cleaning mission.
...tends to replenish a load-zone, by flow-back.
Liquid lubricants will flow to the lowest point of the casing by gravity ...
No, no -- that's not correct thinking for this topic! Capillary attraction is holding the reserve oil. If you experience gravity-flow, you have applied too much oil--or too thin! Granted, after a few cleaning missions, there may be some oil film surrounding the bearing area, but not enough to run down...
...eventually on carpet).
..., is it not the case that grit generally imbeds the softer material, then wears the harder material? ...
The soft nylon gears is the concern here, they are the ones that will embed grit and wear out. You bring up a good point about the shim, since it is harder than the plastic counterparts it's effectively wearing the area out quicker by introducing hard material into the equation. Combine this and oil/dirt into the area, one has effectively lapping compound wearing out the area quicker.
You almost got it right in your last sentence. The tail end of the sentence should read "...lapping compound wearing out the harder metal-shim"; and that would be all right, because the shim is renewable!
FYI: In a machine shop it is common practice to make laps from the soft metals lead or copper. The lap is easily machined to size and shape, and is then *charged* with fine silicon-carbide grit (or graded-size diamond dust), by pushing the grit into the soft material. The lap can then be used to polish very hard, tool-steel items while also finishing them to size.
FYI: In an optics' finishing lab it is common practice to make polishing laps for working glass-optics (or metal-optics) from firm-wax mixtures. The lap is warm-formed to conform to the shape of a reference surface, and then used to polish lens surfaces, or optical flats. A slurry of water and a variety of abrasives are applied to the lap while a special machine oscillates the lap across the part(s), which are held on a rotating spindle. In that process, the wax becomes charged with the abrasive particles, then essentially 'fine-grinds' the glass or hard metal-mirror.
