Performance Differences between Roomba 5xx models
Are there any performance differences between the Roomba 5xx models such as; motor performance, dust bin capacity, battery capacity, cleaning and vacuuming ability.
Let's Live Healthier
- fancyfreewv
- Robot Addict
roddenshaw
- Robot Addict
- fancyfreewv
- Robot Addict
This is a bit misleading. I let both of mine wander through the house at will using the LH/VW only for blocking if I need it. No efficiency is sacrificed due to not forcing them to spend time in one room before letting them into another. The house gets cleaned eventually just as well. Geek Granny also uses her Roombas this way.roddenshaw wrote:The machines themselves don't differ in performance but their inclusion or exclusion of Lighthouse technology will affect their efficiency when cleaning multiple rooms.
Nancy - Mom to 3 Furbabies - Bentley, Chelsea, Whiskey & 3 Roombas - 535 (Half Trax) and 560 (Shadow) and Dirt Dog (Old Yellow)
roddenshaw
- Robot Addict
- fancyfreewv
- Robot Addict
roddenshaw
- Robot Addict
- fancyfreewv
- Robot Addict
http://www.deltechomes.com/
I do have pocket doors in some places and bath and bedroom doors of course. Since these homes have no interior supporting walls, you can just leave things open which is what I did.
There's a lot of madness over there you knowroddenshaw wrote: Not rectangular? No doors? What is this madness you speak of?
- fancyfreewv
- Robot Addict
Henk Poley
- Robot Groupie
I was thinking about those concrete balloon-built dome-houses. They can be made in a day or so, that's without prefab parts.fancyfreewv wrote:http://www.deltechomes.com/
It seems like Deltec builds them by hand from wood?
Nancy, Thanks for that link about circular houses. I didn't know they existed! I love that idea. When I first read your post, I thought you meant an octagon house (http://www.gcv.org/attractions/historic ... agon.shtml).
- fancyfreewv
- Robot Addict
No these are wooden and are built on the site from pre-assembled sections. It takes as long as a normal home to build. Only one post in the center of the hub and spoke flooring and roof design.
Mine has poured foundation above ground that mimics the 14 sections of the sides and then the top floor above that is the wood.
This could be octagon (the smallest size) but they go way up in diameter as you add more sides. I also put two rectangular wings on mine.
