Roomba Battery - is it true ?
dannyhmui
Post by dannyhmui »
Hi guys,
I want to buy a roomba, but I also find many replacement batteries selling on ebay, and other websites, it makes me feel confusing, does it mean the original battery is not enough? Or we really need to replace it? Look at the following links see how many are selling it ! It is true?
http://shop.ebay.com/items/_W0QQ_nkwZroombaQ20batteryQQ_armrsZ1QQ_fromZR40QQ_mdoZ
http://www.amazon.com/iRobot-Roomba-APS-4905-Battery/dp/B00022HZ04
can you give me some suggestion?
stevematlbch
Re: is it true ?
Post by stevematlbch »
Alll rechargeable batteries wear out after some time and will no longer hold much of a charge. Exactly how long this is varies, several factors come into play. I've used my Roomba about daily for about 9 months and it's still fine. When time comes for a replacement you should deal with one of the people on this forum that sell batteries, or, irobot. Most (maybe all) reports on the ebay batteries are not favorable.
Re: is it true ?
Post by mfortuna »
Some of the ebay claims are interesting. One seller has a 2400mah pack that will run for 75 minutes(reasonable), another has a 2000mah pack that will run for 120 minutes(doubtful). Some don't list capacity but say you will get 70% more runtime than other cheap packs. It's 70% better!!!
Let's say the seller wants to make a 20% profit. The list price is $35 and the case costs $4. This leaves $24 for batteries. That's $2 per cell. Cells in that price range are not going to be screened for performance (a process called matching). Some cells may be strong but others could be weak and drag down the overall performance of the pack.
The roomba OEM battery do not appear to be high quality cells but I assume Irobot probably uses screened cells that are of mid range quality. All 3 of my APS packs made it to at least 2 years with medium use (6-8 times a month).
dannyhmui
Re: is it true ?
Post by dannyhmui »
stevematlbch wrote:Alll rechargeable batteries wear out after some time and will no longer hold much of a charge. Exactly how long this is varies, several factors come into play. I've used my Roomba about daily for about 9 months and it's still fine. When time comes for a replacement you should deal with one of the people on this forum that sell batteries, or, irobot. Most (maybe all) reports on the ebay batteries are not favorable.
wow....but you said most maybe all reports on the ebay batteries are not favorable? Why? bad quality or what?
dannyhmui
Re: is it true ?
Post by dannyhmui »
mfortuna wrote:Some of the ebay claims are interesting. One seller has a 2400mah pack that will run for 75 minutes(reasonable), another has a 2000mah pack that will run for 120 minutes(doubtful). Some don't list capacity but say you will get 70% more runtime than other cheap packs. It's 70% better!!!
wow...dude, you are like professional ! I don't even know about that, I just thought so many people selling maybe the reason is original cannot support long, just like notebook battery, some replacement can use longer...but thx a lot for your information...
just another question, 400 series compares with 500 series, 500 series is better right?
dannyhmui
Is it true ?
Post by dannyhmui »
Hi, do you guys also use replacement battery? Where do you guys get it from?
Re: Roomba Battery - is it true ?
Post by mfortuna »
I have bought two yellow APS replacement batteries, one from Irobot and one from Amazon. I bough my two Li-ION packs from vic7677.
As far as your other question is concerned, I don't have a 500 series bot to compare my 400s to. A lot of people have mentioned cleaning ability is similar. Both suffer from brush deck issues, but the new 500s at least use two bearings in the brush deck.
Post by vic7767 »
Sometimes you will be able to purchase the 12 Sub-C NiMH cells from Amazon.com. They offer them on sale at different times of the year. You wil need soldering skills in order to use them.
dannyhmui
Post by dannyhmui »
vic7767 wrote:Sometimes you will be able to purchase the 12 Sub-C NiMH cells from Amazon.com. They offer them on sale at different times of the year. You wil need soldering skills in order to use them.
thx man
jedswift
Post by jedswift »
Just an update, I bought a set last January for about $40, and considered that a pretty good deal. I just checked back and they are now selling the 12 cell 4500mAh set for $24!
http://www.amazon.com/gp/product/B001CP ... B001CP2DJ8
Post by vic7767 »
The 4500 mAH cells with tabs from Amazon for $24 plus $7 shipping is a good deal. If you have the 5XX model all you need to save from the old battery is the small black plastic part since it contains the thermistor and contacts. Then solder the tabs from the cells correctly, install the plastic part, use a little clear aquarium sealant to keep it in place and you're ready to go.
Post by mfortuna »
I just want to point out the claim that they are matched cells is dubious at best. For the price it could be a good battery pack. If matched, each cell would have a label stating average voltage over 25 or 30 Amp discharge, internal resistance, and discharge time.
Scheduler
Post by Scheduler »
mfortuna wrote:I have bought two yellow APS replacement batteries, one from Irobot and one from Amazon. I bough my two Li-ION packs from vic7677.
Whats your opinion on the difference between the APS and the Li-Ion - I have no idea what these are and am trying to wrap my mind around all these available options (NiCd, NiMh, Li-ion, APS, all kindsa different numbers) to determine which is best for me, which is rather hard coz I have to make a decision by this weekend so that it gets here before I move (again !!!) ... Also what is the deck brush issue (I want to make sure I cover all of this before I transfer coz god knows the availability of these things in my new town) ...also do y'all all recommend having multiple batteries on hand ?
esk3
Post by esk3 »
Two things.
NiMh and APS are the same thing.
and
Having multiple batteries is nice, but it is a pain to rotate them in a 5xx series and the extended runtime can cause all sorts of problems with overheating and motor failure and things.
I have two batteries and I only rotate them because I have to in order to keep them both alive. Otherwise, one of them will go bad and will be totally unusable.
Post by mfortuna »
I'm not sure why rotating the batteries would cause overheating. If you run two different batteries back to back yea, but if you run two different batteries every other day you should be OK. Not as easy in the 500 series agreed.
esk3
Post by esk3 »
Right. I meant if you run them back to back. Then there's all of those problems with the CHM motor overheating that people keep asking about.
If you alternate days, then it is a pain, but it won't/shouldn't hurt the robot.
I'll try to be more clear next time.
sxb
Post by sxb »
I am need of a new battery for my 550 which lasted only just over a year. APS or NiCd?
I am interested in value, longevity,etc. I use my robot daily but apparently I did not discharge it enough totally to extend the life of the battery???? I am looking at the ProTech Robotic pages and they have both. Recommendations?
I do not have soldering skills!
Susan
Snohomish
Post by mfortuna »
Getting a year out of a battery that was used daily is not bad IMHO. You can go with either a NICAD or APS (NIMH). You will get less runtime with a NICAD.
