BUT!
I've been thinking for quite some time now that the little filter provided is next to useless and lacked proper engineering.
1) it's leaky, causing fine dust to spread everywhere when i remove the bin
2) it chokes often. due to small surface area of filter and no pre filter. they should get a proper filtration engineer to improve on it.
3) it's poorly designed. in fact, the entire bin chamber is badly designed. look at the roomba aerovac bin - at least somebody is thinking of better ways to manage airflow and dust control. the neato's bin is as sophisticated as a waste paper basket.
4) the filter material is crap.
So being a tinker by nature, I set about making my own HEPA filter.
Here are the pics of Neato HEPA v1
Basically I cannibalized a HEPA filter off my black&decker cyclone vac. 1 filter yields enough material for 2 neato filters.
Then I used silicone and some thin cardboard to seal the edges.
lastly I fixed a fine semi rigid insect mesh over the top as a form of prefilter to prevent large debris from choking up the airflow.
Testing it made made one thing clear:
neato is limiting the suction power of the fan on purpose by design. because of my filter, my resulting airflow is estimated to be twice that of a normal clean original neato filter. and the neato stopped working with an error message asking me to check the bin because it thinks I left the filter out!
I had to place paper and oil filters to obstruct the airflow enough for the neato to work properly (estimated blocking off 60% of the airway)
noise wise, I would say there's not much difference. us neato users are quite used to the sound of its vacuum.
talk about hardware potential!
it's like operating dual i7 hex core CPUs with only 2gb of ram without any heatsinks.
Hope you guys find this useful.
