Will do take some pictures and post it later.piokrza wrote:Hi 3kgt, could you please took some pictures and post here? I'm especially interested in the inside part when dustbin is removed from Neato body and the roller brush is out of the socket. As well, bearing parts on brush ends are interesting parts to see!
Did first run and here is what i can say
Its faster than the first gen neato
More powerfull vacum without any dout! (Testing by airflow in the back)
Dosent come as close to walls wich is bad!
The brush sounds much more (Regular brush, dnt have helix in the botvac) but the motor is Much more quaiter, and the jet sound is gone.
It did hit lower objects a couple of times, but sadly i had to go out and didnt see the whole run!
It did clean my apartment in 1 charge wich is good.
a bit slower than first gean neato on carpet.
Micro usb for uppdates
Overall im happy now! I Would recomended it over regualar neato so far! But hopefully it will come closer to the walls soon..
But i will return this unit and get a Botvac 80 or 85 with Helix brish, the regular brush on hard flour is just too much! If your at home then you will not be able to run it and if you live in an apartment like me you will for sure get sued by others cause of loud sound.
Will put more pictures soon.. guests now
