3kgt has already confirmed the presence of a micro-USB port!glnc222 wrote: There appears to be no way to update the firmware.
Neato Botvac
Re: Neato Botvac
Current Robot's:
Previous Robots:
Evolution Mint 4200
Previous Robots:
Evolution Mint 4200
- a4refillpad
- Robot Addict
Re: Neato Botvac
3kgt thank you very much for all the photos. They have been very comprehensive and useful. Looks like a great bot to me. Personally I've always preferred the beater bar on carpet and the helix on hard floors. The side brush is definitely not a gimmick on hard floors of the edge hugging issue is resolved.
Re: Neato Botvac
+1 great work 3kgt !a4refillpad wrote:3kgt thank you very much for all the photos. They have been very comprehensive and useful. Looks like a great bot to me. Personally I've always preferred the beater bar on carpet and the helix on hard floors. The side brush is definitely not a gimmick on hard floors of the edge hugging issue is resolved.
Now I want one!
Current Robot's:
Previous Robots:
Evolution Mint 4200
Previous Robots:
Evolution Mint 4200
- Robot Master
- Contact:
Re: Neato Botvac
Walmart carries reading glasses along with Neato's.this new LCD color display is so much smaller...
Re: Neato Botvac
LOLglnc222 wrote:Walmart carries reading glasses along with Neato's.this new LCD color display is so much smaller...
Im liking the two touch sensitive buttons for instant spot clean and instant house clean, makes the LCD display a lot less important as you'd only need to use it for setting schedules and the clock.
Current Robot's:
Previous Robots:
Evolution Mint 4200
Previous Robots:
Evolution Mint 4200
- Robot Master
- Contact:
Re: Neato Botvac
Those are almost invisible on cell phones, no wonder. Still can't see where it is in the pics.3kgt has already confirmed the presence of a micro-USB port!
There were some complaints about the XV's obsolete Mini-USB requiring an uncommon, extra cable.
- Robot Master
- Contact:
Re: Neato Botvac
The wall closeness issue is important on carpet. The side brush works only on hard floors, and may fit with the wider wall clearance used in the software. The side brush does not compensate for this on carpets, and the wider clearance is less effective cleaning. Or, with the closer fitting brush, about the same as the XV. Exact measurements would be needed to tell.
Re: Neato Botvac
I just used the cable from my wife's Kindle.glnc222 wrote:Those are almost invisible on cell phones, no wonder. Still can't see where it is in the pics.3kgt has already confirmed the presence of a micro-USB port!
Current Robot's:
Previous Robots:
Evolution Mint 4200
Previous Robots:
Evolution Mint 4200
- a4refillpad
- Robot Addict
Re: Neato Botvac
Yes. There's no reason to leave a gap for the side brush. Due to its size, the side brush needs no clearance. I believe the clearance issue on the botvac is an early bug which should be fixed later on.glnc222 wrote:The wall closeness issue is important on carpet. The side brush works only on hard floors, and may fit with the wider wall clearance used in the software. The side brush does not compensate for this on carpets, and the wider clearance is less effective cleaning. Or, with the closer fitting brush, about the same as the XV. Exact measurements would be needed to tell.
- Robot Master
- Contact:
Re: Neato Botvac
I don't know. They could have had a maneuvering problem with the wall sensor set farther back. Or at least a need for an entirely new maneuver algorithm relative to sensor data -- some programming which did not get done. They have not been known to fix such things very quickly, whatever the issue.
I think the bumper structure has been simplified to reduce the number of separately fastened parts, why no screws visible along the edge.
With the wall sensor off the bumper, it is less a problem to add covering to it as for lowering the edge.
The longer length will make it a little less maneuverable in tight spaces.
- Robot Master
- Contact:
Re: Neato Botvac
Now we know why the last XV model was dubbed "Signature" -- signing off on that generation of design for introduction of the follow-on.
Re: Neato Botvac
[attachment=-1]uploadfromtaptalk1396439844601.jpg[/attachment]
Love robot vacums
Today: Xiaomi Roborock s50
Tested: Neato XV-14,15, Signature pro & Irobot 521,581, 630,650,780 + 2 Samsung modells + XV-25 + Scooba 230, Neato Botvac. Xiaomi Mi and more
Re: Neato Botvac
Ur all welcome
I will try to make a short youtube clip later
Love robot vacums
Re: Neato Botvac
Thanks a lot for the pictures 3kgt !
Re: Neato Botvac
3kgt
Many thanks for the details and photo sharing,
Can you confirm what is the charger amps and voltage the unit gets and also the battery what does it show:
Please Take look inside the charger base ,battery label and what the unit button label shows(hide the S\N if u can)
If you can take the cover off the blower to see what inside.
Many thanks
Many thanks
Re: Neato Botvac
O
Now im upploading 2 short clips on youtube.. u will get link soon. Its a 4K quality with note 3 so its taking its sweet time
First movie is 7gb and secound is 2gb
Will try 2nightshirgal wrote:3kgt
Many thanks
Love robot vacums
Re: Neato Botvac
My new model go-pro camera has a mini-usb port. Not obsolete and IMHO, less vulnerable to damage.glnc222 wrote:Those are almost invisible on cell phones, no wonder. Still can't see where it is in the pics.3kgt has already confirmed the presence of a micro-USB port!
- a4refillpad
- Robot Addict
Re: Neato Botvac
Very interesting how the colour scheme is very very similar to the vr100. In fact, the pure white scheme was always avoided in the past I thought for the very same reason. Now with the introduction of the side brush and the new colours. I wonder if some sort of exclusive contractual obligation had passed between the two companies allowing neato to use previously shared technologies.
Re: Neato Botvac
2 short clips
https://www.youtube.com/watch?v=RMzZr9x9Vpw
https://www.youtube.com/watch?v=cneJ5DsDXgA
Love robot vacums
Re: Neato Botvac
3kgt, thank you for these pics and videos, and your dialogue - valuable info for everyone!
Can you let us know if the laser turret sits lower on the BotVac - even if by a fraction of an inch, I think that would be of great interest to users who have complained in the past of the turret being a sticking point of the XV series not being able to get completely under some furniture.
