It arrived today and it's in pretty good physical shape, only a couple of scuffs here and there. Sadly, the LCD is blank all the time but everything else appears to be working!
I've used the NeatoControl program to test all the sensors and motors, everything looks good. The batteries were giving me about 8.3v each on a DMM but the internal fuel gauge was only reading 14%, which I guess is why the seller couldn't get it to run, especially with no error on the display. I set the battery to 100% and it burst into life.
I will perform the battery conditioning procedure at some point and see how good the batteries are - they look like the originals so they probably won't last long...
Now I just need to strip it down and give it a good clean, free up all the bearings, change the caps, etc. I think I can live without the display for the time being; it won't take long to find my way around the invisible menu and I can always set up scheduling with NeatoControl.
I gave it a quick run in an area of about 2 square metres and I was amazed at the amount of fluff it picked up!
Thanks again!
