Thank you very much!!!
It helps me a lot!
Juts few remarks based on my experience repeating this:
1) If you decide to proceed with LCD like it described (to fix mirroring) then you may leave original back light LED. In my case it was stayed on pcb while i was removing broken LCD and I decide to solder them out later one, but finally find out that its good to leave them as well as original plastic thing that was under the original LCD.
2) If you decide to proceed WITHOUT switching neato off (I was not sure in my result and decide to keep my current schedule in memory, If it wiped - then its almost impossible to setup it again without LCD) then you need to know that after connecting - you need to press buttons (In my case it was: start working, pause, stop) to see images on LCD, other wise it will stay blank (looks like each time you start/stop it reinitialize LCD)
3) If it your first time soldering 0.5mm (like it was for me) order two connectors!!! And ensure that you understand soldering techniques
It was good that I order two of them like it was reccomended here.
Once again - THANKS A LOT, It is awesome!!!
PS: I was mistaken and order smaller LCD... but they still compatible
