Hello to all,
I bought a new battery for my Neato D6 connected... helas after initialy working great .. I presume it was because the battery was full ...in little time it was empty and it appeared that the D6 was not charging it...
I connected the robot to Neato Toolio in order to try the newbattery command.... but each time I go into testmode ....the robot reboots and I cannot try the newbattery command
I can only assume that when the command is entered the robot does not rely on external power ...but as the battery is discharged...it cuts the power...
How can i do ?
I would like to try to charge the battery externally but I'm not sure how to do it... is there anyone that can help ?
Best,
Paul
Neato D6, new battery problem unable to use Toolio
Re: Neato D6, new battery problem unable to use Toolio
Hi ,
I face the same problem with my D7 .
It just restarts when I sent Testmode On command.
Battery starts shows green on robot LED , in robot control and neatotoolio is shows 16v in first bar est all shows empty and no value.
Plz help thanks
Plz help thanks
- CodaCM
- Robot Master
- Contact:
Welcome to RobotReviews!
Have you tried a new battery? If it is a brand new battery, I recommend contacting Neato Support. https://support.neatorobotics.com/support/home
Coda
Most "Active" Forum Mod
Neato Question? Check out the Support Tools list I made.
martymaks88
I have the same issue as you with my neato that doesn't want to go to testmode as th ebattery is completely down.
Did anyone find a solution for this by any chance?
Kr
Maks
Kr
Maks
- CodaCM
- Robot Master
- Contact:
With the number of reports I've seen, I think it could be a hardware defect or a general battery failure.
Sorry, I can't really provide any more help.
Coda
