Roomba 560 docking issues
wowwee_fan
Post by wowwee_fan »
Irobot roomba 560.
I bought this off ebay and It was missing one of the brushes for edges, and the battery was having problems so I took it apart, replaced the brush and cycled all the cells(as per google directions and help of the seller i bought it from) in the pack to check for bad cells but cycling them brought them all back to life so the battery does work now but it has trouble finding its charger sometimes.
It does work just fine but after looking for a while it does its (uh-oh) sound and stops I have not tried to start it from the charger though, any ideas on why its stopping?
I can't figure out why it can't find the charger either..
:help:
Re: Roomba 560 docking issues
Post by vic7767 »
There is a program running in the Roomba that monitors the battery level. At a certain point (some say 12 volts) it will trigger the search for home base program function. If the battery does not have enough capacity reserve then it will not be able to provide the power needed to locate and dock on the home base. This is normally what happens to a used/worn battery over a period of time.
wowwee_fan
So maybe replacing the battery might work out, :D
marymac
Post by marymac »
I thought the Roomba had to start from the charger base in order to return to the base.
" I have not tried to start it from the charger though, any ideas on why its stopping?"
wowwee_fan
I did try starting it from the base charger but it doesnt finish the area. Instead it goes around and then sings its little do do do do do do song, and stops. :think:
marymac
Post by marymac »
That means the base charger is in a place not readily visible to the Roomba. Or you're not placing the lighthouses effectively. It takes a little time to figure out where to place all these things so the Roomba has enough guidance and power to return home.
wowwee_fan
Ok ill move them let me try that and I will repost
wowwee_fan
Ok, I moved the wall sensors and the docking system, Roomba ran well and still died before getting back to base. :roll:
marymac
Post by marymac »
Maybe the area to be cleaned is too large for the Roomba. Decrease the cleaning area and see if it can return to dock. How long is it running before stopping?
marymac
Post by marymac »
When you open RobotChat, read the 4th topic down about lighthouses and docks - it has great information that may solve your problem. It's titled "Roomba 5xx Series Lighthouse and Virtual Wall Information"
http://www.robotreviews.com/chat/viewto ... =1&t=11048
wowwee_fan
Thanks i will try moving the sensors and blocking the area off .
wowwee_fan
Ok moved sensors last night and ran roomba this morning, Still same results, I am about ready to pull my hair out ! The only other thing I can think to do is lock him in a room and keep moving him around. :cry: :cry:
Post by mfortuna »
As vic mentioned you may have a bad battery. What is the total runtime you get?
On a new battery you will get more time to find the dock when the robot detects the battery is low. On an old battery you get less time to find the dock.
I'm not sure how to do this on a 500 series but you can also try to force it to find the dock while the battery level is still good. On the 400 series pressing the spot and clean buttons at the same time will force it to seek the dock.
Post by vic7767 »
On the 535 that I have there is a Dock button that will set the Roomba into home base seeking mode.
wowwee_fan
I get a run time of about 45 mins to an hour on a good day. Where can I find a battery?
wowwee_fan
Ok, I found a battery on ebay i will order it and go from there
wowwee_fan
Ok got battery in and ran roomba today,. still same issue !!!(they need a smilie pulling their hair out" :doh: :doh:
marymac
Post by marymac »
Did you charge the new battery in the Roomba for at least 16 hours? That might be a good idea.
wowwee_fan
yes i did.... charged all night and most of day about 20 hours. :mrgreen: :mrgreen: :violin: :violin:
Post by vic7767 »
What kind of run times are you getting? If the run times don't improve over what you had in the past then you still have the same capacity issue the original battery displayed.
