One of my two Scoobas when I hit the power button turns on green for a moment; but does nothing else.
Any idea?
Scooba don´t work.
- vic7767
- Robot Master
Re: Scooba don´t work.
What model Scooba ?
ecologymagnet
Now I cleaned the tank with hot water and the other Scooba does the same, to turn it on the led a moment; but does nothing else.
- vic7767
- Robot Master
What is the battery voltage?
ecologymagnet
6 nimh 8,4v Full charge.vic7767 wrote:What is the battery voltage?
I don´t use the conector T but before run correctly without T conector.
- vic7767
- Robot Master
How old are the cells? Have you done a load test on that pack? It appears to discharge very quickly in the video.
ecologymagnet
I hit the bumper and one has come back to work; but the other did not.
One not work.
The cells are ok.
One not work.
The cells are ok.
