Neato Firmware 4.6.0_72
hillcountryfare
Post by hillcountryfare »
While troubleshooting another issue I noticed a few screenshots of Botvacs running 4.6.0_72. I was able to compile this version and add in the updated certificate, valid until 2/10/24. This version is fully compatible with the Neato iOS mobile app. I tried 4.6.1_102 and higher, and those won't register through the mobile app. It's unclear what's different between this version and Neato_4.5.3_189.
Feel free to rehost elsewhere, this was the first option that came up on Google.
https://file.io/trWS7x4dmA94
crunchtime2k
Re: Neato Firmware 4.6.0_72
Post by crunchtime2k »
This is awesome you located this, could you repost or pm a link as this link is dead
Thank you
crunchtime2k
I was able to grab this from the aws backend actually , so if he doesnt repost i will pack this up with a updated cert for all
mdblack98
Post by mdblack98 »
Has anybody reposted this?
Sure would like to get the newer firmware as I think it fixes the DST problem.
freewind
Post by freewind »
I do not recommend this firmware.
1. Does not correctly detect doorways. Unlike 4.5.3-xxx, does not clean by room
2. Very poor algorithm for going around the room perimeter, does not go into corners.
3. Does not work correctly with Chinese replica batteries (possibly a problem with my robot). Firmware 4.5.3 works fine.
CodaCM
Contact:
Post by CodaCM »
freewind wrote: March 22nd, 2025, 10:14 am I do not recommend this firmware.
What model of Neato do you own?
Coda
Most "Active" Forum Mod :dance:
Neato Question? Check out the Support Tools list I made.
