Neato D6, new battery problem unable to use Toolio
sapym
Post by sapym »
Hello to all,
I bought a new battery for my Neato D6 connected... helas after initialy working great .. I presume it was because the battery was full ...in little time it was empty and it appeared that the D6 was not charging it...
I connected the robot to Neato Toolio in order to try the newbattery command.... but each time I go into testmode ....the robot reboots and I cannot try the newbattery command
I can only assume that when the command is entered the robot does not rely on external power ...but as the battery is discharged...it cuts the power...
How can i do ?
I would like to try to charge the battery externally but I'm not sure how to do it... is there anyone that can help ?
Best,
Paul
B04aha
Re: Neato D6, new battery problem unable to use Toolio
Post by B04aha »
Hi ,
I face the same problem with my D7 .
It just restarts when I sent Testmode On command.
Battery starts shows green on robot LED , in robot control and neatotoolio is shows 16v in first bar est all shows empty and no value.
Plz help thanks
CodaCM
Contact:
Post by CodaCM »
B04aha wrote: May 10th, 2025, 9:36 am Hi ,
Plz help thanks
Welcome to RobotReviews!
Have you tried a new battery? If it is a brand new battery, I recommend contacting Neato Support. https://support.neatorobotics.com/support/home
Coda
Most "Active" Forum Mod :dance:
Neato Question? Check out the Support Tools list I made.
:text-search:
martymaks88
Post by martymaks88 »
I have the same issue as you with my neato that doesn't want to go to testmode as th ebattery is completely down.
Did anyone find a solution for this by any chance?
Kr
Maks
CodaCM
Contact:
Post by CodaCM »
With the number of reports I've seen, I think it could be a hardware defect or a general battery failure.
Sorry, I can't really provide any more help.
Coda
:text-search:
mmm2000
Post by mmm2000 »
Had the same problem after I had my D7 disconnected from the base for a few days. The battery wont charge anymore.
That was several months ago. I did ended up fixing it with one of these software tools, but I forgot how I did it... The solution has to be here on the forums somewhere.
Now I did it again and my robot wont charge, with a fairly new battery...
mmm2000
Post by mmm2000 »
Solved:
Here what I did:
Open Toolio
Click Serial/Settings
Click on Auto detect Neato
Select COM3 (in my case)
Click on Serial Connect
Now the robot should be connected
Next:
Click Debug/Terminal
In the Command field, type:
testmode off
testmode on
newbattery
Then you should see the message: NEWBATTERYNew battery inserted.
For me if I try anything else, it would reboot the robot every time (I think when a command from the UI would try to do TestMode ON)
If I do it manually, in the terminal then TestMode ON works for some reason. Odd, but it works and then you can type the NewBattery command/
I hope this works for others too. Please reply if it does.
Cheers
